Tidak bisa di isi daya / Cannot be charged
Android mati dan jika diisi daya tidak bisa
Android is dead and can't be charged
@lexaagustina you are not giving us enough information. You need to consider letting us know if anything happened to your phone. It is important to know if it just stopped charging and what have you checked and tried to fix it.
First you want to check your charger. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc., use a few puffs of air to clean it out. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get an ammeter and see if your phone draws any amperage from the charger.
You may also have to consider replacing the battery. A depleted battery can no longer be charged. Measure the voltage on your battery connector with the charger plugged in. You should get around 4.2V If you don't get that voltage check your flex cable coming from the charging board. Make sure it is seated properly and does not have any tears or other damage on it. Your phone has a separate charging board that could be faulty. Consider replacing that.
Since iFixit does not yet have a specific guide for that, use something like this guide It was written in Spanish so use a browser that does the translating for you, If needed. Replacement charging boards are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this. Repair is War on Entropy!
Translation
@lexaagustina Anda tidak memberi kami informasi yang cukup. Anda perlu mempertimbangkan untuk memberi tahu kami jika terjadi sesuatu pada ponsel Anda. Penting untuk mengetahui apakah pengisian daya baru saja berhenti dan apa yang sudah Anda periksa dan coba perbaiki.
Pertama, Anda ingin memeriksa pengisi daya Anda. Pastikan tegangannya sesuai. Periksa untuk memastikan konektor tidak bengkok dll. Setelah itu, periksa port pengisian daya. Bersihkan dari kotoran dll., gunakan beberapa hembusan udara untuk membersihkannya. Pastikan tidak ada korosi, serpihan, dll. yang menghalangi kerjanya. Jika tidak ada yang berhasil, dapatkan ammeter dan lihat apakah ponsel Anda mengambil arus listrik dari pengisi daya.
Anda mungkin juga harus mempertimbangkan untuk mengganti baterai. Baterai yang habis tidak dapat diisi lagi. Ukur voltase pada konektor baterai Anda dengan pengisi daya terpasang. Anda akan mendapatkan sekitar 4,2V. Jika Anda tidak mendapatkan voltase tersebut, periksa kabel fleksibel yang berasal dari papan pengisi daya. Pastikan terpasang dengan benar dan tidak ada robekan atau kerusakan lainnya. Ponsel Anda memiliki papan pengisi daya terpisah yang mungkin rusak. Pertimbangkan untuk menggantinya.
Karena iFixit belum memiliki panduan khusus untuk itu, gunakan sesuatu seperti panduan ini Itu ditulis dalam bahasa Spanyol jadi gunakan browser yang menerjemahkannya untuk Anda, Jika perlu. Papan pengisi daya pengganti sudah tersedia di banyak toko online.
Saat Anda menggunakan ponsel, ambil banyak gambar. Setelah Anda selesai melakukannya, ambil gambar itu dan buat panduan untuk iFixit. Itu akan membantu orang berikutnya yang memiliki perangkat dengan masalah yang sama seperti Anda. Sangat mudah dan menyenangkan untuk membuat panduan ini. https://ifixit.com/Guide/new Komunitas iFixit akan menghargai ini. Perbaikan adalah Perang Melawan Entropi!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 7
总计 7
