跳转到主内容
加入维修社区 - 创建账户
Lenovo Legion 5-15IMH05 是一款为高性能需求而打造的电竞笔记本电脑。其擅长游戏、编程和内容创作。此设备页面可帮助用户识别自己的 Legion 5 型号,并获取关于电池故障、设备过热、存储升级以及键盘或显示面板问题等常见问题的技术规格、服务文档和维修资源的官方可靠帮助。
My Ethernet Connectivity Issue
For some reason my ethernet stopped working, I tried a new ethernet cable and different router and it was still not connecting. After further investigations about the problem, it seems that my laptop itself is the problem. It would only say "no connection" how do I fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @christianmamon
What is the status of the LAN network adapter shown in Device Manager?
Go to Device Manager - Network Adapters - right click on the LAN adapter entry - Properties - General - Device status box.
Does it say, "this device is working properly"?
To get to Device Manager in Win10/11 press the Win key and the x key (both together) and click on the Device Manager link.
If it is OK try resetting the TCP/IP stack and check if it works OK.
If there's a red cross next to the LAN adapter entry in Device Manager, right click the entry - Enable and check if it works OK.
If there's a yellow exclamation mark next to the LAN adapter entry in Device Manager, right click the entry - Update drivers and follow the prompts. You need to be online for this procedure to work. Try WiFi perhaps.
这个答案有帮助吗?
得分 1
4条评论:
Hello! will this work the same with "no internet access" problem?
由完成的
@christianmamon
Not sure what you mean.
The above is just checking if the LAN adapter on the motherboard is working OK so if it checks out OK and you have reset the network in the laptop, all you can do is try it and see.
Have you checked that there's no "bent" or missing pins in the Ethernet port on the laptop?
由完成的
@jayeff I have, nothing is missing, though Im concerned that it keeps going back to identifying even if it connected earlier
由完成的
@christianmamon
If the adapter status is OK and you have reset the TCP stack there's a problem on the motherboard as it isn't connecting to the router.
由完成的
添加一条评论
添加你的答案
Christian Mamon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 55
总计 1,472
