跳转到主内容
加入维修社区 - 创建账户
苹果于2021年9月更新iPad mini,配备A15 Bionic处理器,8.3英寸屏幕,全新设计,侧边按键式触控ID,并且支持第二代Apple Pencil。
What causes the colored strip after installing a new digitizer screen?
Hello, This iPad had a badly broken digitizer and screen. I installed a brand new digitizer screen assembly using clamps to ensure a firm and consistent seal. What could be causing the new screen to have a colored strip with various colored lines on the left side of the screen?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Is this problem similar to the one you replaced it for?
完成的
@hampter Not that I am aware of although parts of the screen were black/unreadable from being broken.
完成的
@timothyyoder that is very good to hear i had a little suspicion that this wasnt a screen problem, but if the crack is different then you just put the clamps too hard follow turkey’s advice
完成的
After replacing the digitizer screen assembly for the second time (no clamps used) the screen works well. Problem Solved.
完成的
添加一条评论
2个答案
已选择的解决方案
@timothyyoder looks like a damaged screen. Time to replace it once more, just this time skip any clamps since those can cause pressure damage.
这个答案有帮助吗?
得分 1
4条评论:
Just what I was suspicious may have happened. Guess I’ll prove it with a new screen. Thanks for your input.
完成的
@timothyyoder hope it works out for you. Let us know what happens after you change it once more
完成的
IFixedit! I installed a new digitizer screen assembly. It works well now.
完成的
@timothyyoder AWESOME. Thank you for coming back to let us know! Repair is War on Entropy!
完成的
添加一条评论
最有帮助的答案
Hi Tim, digitizers are extremely delicate and there may be a chance that during the installation that some debris or small particle could have put pressure on the screen and cause the ribbon. I would try to disassemble it as carefully as possible and examining if whether or not there is significant damage to the digitizer underneath. Hope this helps!
这个答案有帮助吗?
得分 1
1条评论:
Thank-you for your advice.
完成的
添加一条评论
添加你的答案
Timothy Yoder 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 20
总计 346
