跳转到主内容
PlayStation 3 Slim是PS3的第二个迭代机型,机器型号CECH-2000。索尼电脑娱乐推出此机型来修复初代“胖机”PS3的诸多硬件问题,于2009年9月1日发布。
ps3 slim does not load disks
Hi guys
I have a ps3 slim model CECH 3001B bought in USA six months ago. One day when I turn on I found that the play can´t load any disk.
It seems that there are some kind of missaligment with the mechanims but I can´t find it.
Are there any guide step by step to realing the mechanism?
Thank you very much
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Just to make sure, you did check to see that there is not already a CD in the drive?
完成的
添加一条评论
1个答案
已选择的解决方案
marcelo, I have not come across any of the guides for adjustments on the loading mechanism. There is a decent video on youtube that shows how to replace the laser. It might show you more of the optical drive. Now, if you check this video, it appears that there is a possibility that it is caused by a misaligned laser motor.
这个答案有帮助吗?
得分 2
2条评论:
thank you oldturkey03.
The problem started with a disk inside, when I turn on the PS·3 the sistem did not read the game, then I ejected the disk and when I tryed to reload it the PS3 did not load the disk
Marcelo
完成的
Marcelo, if it did not pull the disk in then there is a problem with the loading mechanism, if it does not read the disk, it is most likely an error with the laser assembly. In either case, you will have to disassemble your optical drive and further investigate, or replace the drive.
完成的
添加一条评论
添加你的答案
marcelo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,720
