跳转到主内容
加入维修社区 - 创建账户
Bosch GCM12SD 是一款有线电动斜切锯,配备 12 英寸双斜角滑动导轨系统和硬质合金钢锯片。本页面提供了该产品的详细信息和维修指南,其特点包括用于提高精度的 SquareLock 围栏设计、用于改善对齐的轴向滑动系统,以及方便的免工具更换锯片机制。
Speed change after replacing blade
I put a new, compatible, saw blade in my GCM12SD miter saw. Since then the saw is slower to spin up and slower to spin down. Is this normal? Is it a symptom of over tightening the new blade? The saw appears to cut normally once at full speed.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Do you know of your old blade may have been a thin kerf blade? If so it would have been a lighter blade which would have less drag on the motor at start up. Or if you had a different brand blade that may also have been a lighter weighted blade in comparison to your new one. If your saw is showing no other issues while cutting and it's only a matter of a little slower start up it may just be an issue of what I described. Over tightening wouldn't be an issue. Just keep your eye open for anything that doesn't seem right while cutting like new vibrations or movement while cutting as that would indicate bigger /serious issues potentially.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bigband 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 159
