跳转到主内容
松下数码相机的维修指南。
Panasonic FZ1000 II LCD screen backlight not working
Hi all,
i have a Panasonic DMC-FZ1000 II where the LCD screen backlight is not working,
the screen works and can be seen if you tilt the camera to one side but there's no backlighting whatsoever.
I have replaced the driver board and the actual screen, and the connecting cable but still cant get this working, im assuming the motherboard has an issue, does anyone have the pin outs for the screen so i can check if the mother board is sending any voltage out to the screen ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@chrisbickley Since we can't see your circuit boards, this is hard to point out. It does sound like an issue with the backlight circuit. Most cameras have a backlight fuse as well as a power fuse. Do check on your camera PCB's for any "odd looking" component. Then post some pictures of what all of that looks like, with your Question.
在已经存在的问题里加入图片
Update (06/27/24)
@chrisbickley it sounds like an issue with the backlight power. You said you replaced the LCD screen and the Driver board but you did not tell us what you are referring to as the driver board. This could easily be an issues with a DC-DC converter. Check the Backlight (BL) connector on the main board as well as on the LCD connector for DC power.
这个答案有帮助吗?
得分 2
1条评论:
Ive added a picture of the mother board, ive checked the connectors and they seemed fine in fact, the two connector cables which are absent here are new also.
As i dont have a service manual for the FZ1000 II (i dont think they are available ?) i dont know where to start with this or probe to see where power should be coming from to the LCD screen.
完成的
添加一条评论
添加你的答案
Chris Bickley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 119
