跳转到主内容
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
majoir problems with my psp go
the firsst problem is the right side of my psp go is disconnected from the main body and everytime it moved it would just shut off, my next problem is well unclear too me casue thee way i remember it was that that my pspgo would not charge but also it will not turn i even used my friends charger still nothing happened so i guess the charging station is broke.or my psps just wont turn on can some one help cause i have a lot of games on my pspgo that i cant play but would like too
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Braylon Foreman, the first thing I would try to make sure off is that your battery is working. There might be a possibility that it is not holding a charge. The other thing you can try and do is to check the fuses on your GO to make sure they are working. Also, check the logic board for any damage, debris, corrosion. You can clean it with isopropyl alcohol. Hope this helps to get you started. Good Luck.
这个答案有帮助吗?
得分 1
添加一条评论
go to sitting check if corging thing is on
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Braylon Foreman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,666
