跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Why won't my iPhone turn on after I dropped it in water?
I had a car crash about a year ago and my iPhone 3gs fell into a puddle. I didn't really bother to dry it out properly and i just let it sit by the window so the sun would hit it. I tried to turn it on and i can see the apple logo light up (but the screen won't really "light up" it is dark but you can barely tell that it does come on) and then it goes to the screen where it says to connect to iTunes. I try connecting it to iTunes but it gives some type of error and nothing happens. Do i need a new hard drive, logic board, battery, or new display? any recommendations?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论
What error does it give you? Be specific since it can mean a lot. Also, the iPhone does not have a hard drive.
完成的
i connect it to iTunes and it tries to update software and restore but after the software is downloaded, an error box pops up and says "the iPhone "iPhone" could not be restored, An unknown error occurred (2001.)"
完成的
freddyibms, "Error 2000-2009 (2001, 2002, 2005, 2006, 2009, and so on): If you experience this issue on a Mac, disconnect third-party devices, hubs, spare cables, displays, reset the SMC, and then try to restore. If you are using a Windows computer, remove all USB devices and spare cables other than your keyboard, mouse, and the device, restart the computer, and try to restore. If that does not resolve the issue, try the USB issue-resolution steps and articles listed for Error 1604 above. If the issue persists, it may be related to conflicting security software." Check on here http://support.apple.com/kb/TS3694 for more on how to resolve it....
Thanks for accepting my answer.
完成的
添加一条评论
1个答案
已选择的解决方案
freddyibms, my suggestion would be to kind of start from scratch. Since It is possible that you phone is suffering from water/corrosion damage, use these guides to disassemble you phone, and this guide to clean your water damage. After that, replace the battery and re-evaluate your phone for any damage. Since you can see your screen, just not lighting up, it sounds like you are having backlight issues. If, after trying to fix the water/corrosion damage, you still do not have a backlight, start by replacing the LCD, if that still won't work, check on your 6R8 coil. Watch this video and see if that is something you would tackle. Okay, and if after that ;-) you still do not have a backlight, it is possible that you have an IC problem ( It is the 109L). Anyhow, I hope this helps to get you started, good luck
这个答案有帮助吗?
得分 0
1条评论:
Thanks a lot oldturkey03! This is exactly what I was hoping for. I'll try some of these tips and I'll come back and update as soon as possible.
完成的
添加一条评论
添加你的答案
freddyibms 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 5,526
