跳转到主内容
加入维修社区 - 创建账户
2018年7月发布,15英寸 MacBook Pro,型号 A1990,拥有 15.4 英寸 LED 背光显示屏,支持 True Tone 原彩显示技术、Touch ID,最高搭载 6 核心酷睿 i9 处理器。
Need help diagnosing display issues
My 2018 MacBook Pro display is shpwing flickering green and red lines, and occaionally blacks out or has a block pattern. I cannot locate any cracks in the screen, and the laptop has not been dropped since I have owned it. Graphics display perfectly when using Airplay to cast to my TV. Does this seem to indicate a display cable issue, or should I be looking at replacing the screen? Thanks in advance for the help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
This is most likely due to a failing display flex cable, which unfortunately is integrated into the display assembly. This is a common design problem with these models (2016-2018ish Pros). Unfortunately you'll need to replace the display assembly to repair the device. Sorry!
这个答案有帮助吗?
得分 1
1条评论:
That’s what I thought originally, I just needed some confirmation before I under the process. I already bought a replacement display as simply, I just had not installed it. If there was any other options, I wanted to explore that first. Thanks a bunch!
由完成的
添加一条评论
Saludos que me recomienda MacBook Pro 2018 15 pulgadas modelo a1990
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tanya Robinson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 261
