跳转到主内容
索尼 PlayStation 5 DualSense 手柄(第一代)的维修指南,拆解信息和支持文档。本产品型号为 CFI-ZCT1W,主板型号为BDM-010。DualSense 系列手柄取代随 PS4 同期发布的 DualShock 系列手柄。
Why does L2 only register if I press down hard?
My L2 button wasn't working after I, stupidly, sprayed some silicone lubricant in it to stop it from squeaking. I disassembled the controler and cleaned the entire L2 assembly with alcohol, the button, ribbon and surface underneath. L2 works again but only if I depress it all the way and squeeze hard. I'm fairly sure it's clean now, but not sure what else could cause this? Any help would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Zander!
Most of the time caused by the L2/R2 that's not aligned correctly. Or a issue with the spring.
You can check this one out: https://www.youtube.com/watch?v=DvdgAis9...
Please check if everything is seated correctly.
Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zander 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 135
