跳转到主内容
加入维修社区 - 创建账户
Asus A541U 系列是 Asus Vivobook Max 系列的一部分。其中包括在不同年份发布的 A541UA、A541UAK、A541UJ 和 A541UV 机型。
The Wifi icon is missing
Why am I not getting a wifi icon on my laptop?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
you must install the driver, use the drivers software
完成的
添加一条评论
4个答案
最有帮助的答案
Hi @carol66188
Have you tried pressing the Fn+F12 keys (both together to check if the WiFi turns on and not that the laptop is in airplane mode?
If still no good, check the status of the WLAN adapter in Device Manager
To get to Device Manager in Win10/11 press the Win key and the x key (both together) and select the Device Manager link that in the menu options that opens.
When in Device Manager scroll down to Network Adapters and click on the > symbol to expand the list, right click on the Realtek WLAN driver entry → Properties → General and check what it says in the Device status box. Does it show "this device is working properly"?
If there's a red cross next to the WLAN entry right click on the entry → Enable and check if it works OK
If there's a yellow exclamation mark next to the WLAN entry, right click on the entry → Update drivers and follow the prompts. You need to be online (Ethernet cable connection to your router) for this to work.
If there's no WLAN entry in Device Manager (also check if in Other Devices category (if listed) and also click on View → Show hidden devices to make sure that it is not listed in Device Manager at all), restart the laptop and get into BIOS on startup. To get into BIOS press the F2 key after starting the laptop.
When in BIOS go to the Security tab → LAN network Interface → Wireless Network interface → Unlock
If all the above appears to be OK then it may be that the WLAN card in the laptop is faulty and will need to be replaced.
这个答案有帮助吗?
得分 1
1条评论:
also can try downgrade to win10,so many asus laptop after upgrade to win11 ,suddenly wifi lost.
完成的
添加一条评论
I had the same issue with my laptop not showing the WiFi icon. What worked for me was checking if my WiFi was enabled in the settings. Sometimes, updating or reinstalling the network drivers from the Device Manager can solve the problem. Also, ensuring airplane mode is turned off helped. If you still face issues, restarting your laptop or checking for Windows updates might do the trick. Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
You can check the wifi adapter inside the laptop that is wired to the motherboard it should be visible when you unscrew the back of the laptop
There could be shortages inside the circuit if it is shortages try to identify it with a multimeter
If there is not any shortages then there could be missing software updates or drivers
这个答案有帮助吗?
得分 0
添加一条评论
If your laptop isn’t showing a Wi-Fi icon, it usually means Windows isn’t detecting the wireless adapter. Try these quick fixes:
  1. Check Airplane Mode – Make sure it’s off.
  2. Enable Wi-Fi Adapter – Go to Control Panel > Network and Sharing Center > Change adapter settings and ensure Wi-Fi is enabled.
  3. Update or Reinstall Drivers – In Device Manager, expand Network adapters. If Wi-Fi is missing or shows a warning, reinstall the driver from your laptop manufacturer’s website.
  4. Restart WLAN Service – Press Win + R, type services.msc, and restart WLAN AutoConfig.
  5. Check BIOS – Ensure wireless is enabled.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Carol 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 41
总计 717
