跳转到主内容
加入维修社区 - 创建账户
Kenmore 品牌 Kenmore 80 Series 洗衣机的维修指南。
Help to Remove the Top
I've taken apart plenty of washers but this one is different and incredibly frustrating. I have a Kenmore 80 Series 110.16862502 and I cannot open it up to change the latch switch. Any suggestions? Nothing like it online anywhere. The back is one piece and the side caps are screwed to the control panel from the inside.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
最有帮助的答案
Hi @stephenhol62543
Here's a technical service aid that covers your type of washer that may help.
Go to p.19 to view how to access the control panel and then p.22 for how to access the internal components of the washer.
这个答案有帮助吗?
得分 1
添加一条评论
Normally, prying a screwdriver into the seam between the top and the bottom will unsnap the retainers there. Once that is open you will have access to other things.
这个答案有帮助吗?
得分 0
添加一条评论
请参阅图像内容:
这个答案有帮助吗?
得分 0
4条评论:
Looks like there are screwed holding them together. Do I need to pull the whole shroud off at the same time?
由完成的 分享
something is going to snap open. Obviously, you can't unscrew things that are inside if you can't get inside. Sometimes those clip can be a PITA.
由完成的 分享
They are definitely screwed in from the inside, I'm wondering if I have to lift the whole thing up over the drum, this is ridiculous!
由完成的 分享
I have almost the same identical washer. I used a plastic putty knife pushed forward directly under the side panels on both sides and it popped open. The metal clips are only 1/2 inch from each end of the top panel. I believe on earlier models the clips are farther from the edges (and on those you can remove the side panels).
由完成的 分享
添加一条评论
I need to change the drain pump. It looks like later models have much easier disassembly.
I still cant figure out how to get the control panel to tilt back.
There are two screws in the back top corners that looks like where the cover that has the dials is loosened,
but they are removed and the control section won't budge and the plastic side covers don't appear to move.
what am I missing. This looks like the original model 80 series.
这个答案有帮助吗?
得分 0
2条评论:
Hi @thewizardofahhs
What is the model number of the washer?
由完成的 分享
having the same trouble getting control off kenmore 80 series mod no 110.26852503. i just need to change lid switch
由完成的 分享
添加一条评论
Bill and Stephen N above are correct. I had to push with a putty knife so hard the clip dislocated from it's connection to the control panel but then it opened
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stephen Holt 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 32
过去 30 天: 137
总计 3,421
