跳转到主内容
加入维修社区 - 创建账户
Asus TUF Gaming A15 于 2022 年初发布,配备 AMD Ryzen 4000 系列处理器、RTX 或 GTX 系列显卡,以及一块 15.6 英寸的 1080p 屏幕。
Wifi connection always disappearing
It happens everytime I run my laptop for a short amount of time and it has been really frustrating. Its either disappearing wifi icon or cant connect jacksh*t.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
This issue stems from the mold design of the TUF Gaming series. Specifically, when you install two SSDs (sometimes even just one), the WiFi module overheats, causing the WiFi connection to drop. The fix is often quite unpredictable... I’ve experienced this same problem myself; it’s happened around twenty times during my six years of use (2020–2026).
There are many solutions online. I’ve tried:
1. Discharging static electricity (didn’t work)
2. Deleting/disabling the WiFi 6 module in Device Manager, then re-enabling it (sometimes works)
The most fundamental solution is to buy an external WiFi adapter, which would completely resolve this issue. However, using a laptop like this can be quite frustrating.
Alternatively, you could consider buying a new laptop. (Given the current hardware market, where PC prices are heavily inflated, it’s probably best to make do with what you have for now—comparing it to a new computer where the WiFi module is essentially free.)
由完成的
添加一条评论
5个答案
已选择的解决方案
Hi @yfanthenial,
Have you checked that the latest WLAN drivers are installed?
Try using the laptop as close as possible to your network router i.e. <20cm and check if you get a stable WiFi connection.
If so, there may be an antenna problem (loose connection) in the laptop.
Here's a teardown video that shows the WiFi antenna being disconnected from the WLAN card at ~2:20 minutes into the video that may help.
You can also download, install and run this free WiFi sniffer program¹ to see if signal interference may be the problem.
The program will tell you the signal strength of your network (and any other visible networks that can be detected by the laptop). The value of the signal is in -dBm so the higher the numerical number, the lower the actual signal strength is. Here's an article that explains it better then I can.
Having a low signal strength can cause instability in the connection. Also sharing the same WiFi channel with another network can also cause problems if the signal strength of their network is high in relation to your network. If there is then one way to overcome this is to change the channel in your router (see your router documentation) to a quieter channel i.e. one with no or the least appearances as shown by the program. Most network routers default to channels, 1, 6 or 11 straight out of the box and most people don't bother to change it when setting up their network.
¹I think that to avoid having to sign up, scroll down to inSSIDer 4 for Windows and download it there as this version is sufficient for what you want.
这个答案有帮助吗?
得分 2
添加一条评论
hi @yfanthenial, @jayeff
i have suffered from this problem after some windows update. this issue irritate me when i play the game. i have applied the tons of the solutions but any kind of solution not working.
one day i decided to check the physical connection of the drivers.
i changed the location of my SSD to second slot of the motherboard.
i dismantled the WIFI & BT driver, and cleaned the connections of the driver, after that i have again installed the physical diver to the mother board.
guess what i got the permanent solution.
after that WIFI & BT never disappear again.
这个答案有帮助吗?
得分 0
添加一条评论
Uninstall your Wifi driver, and restar your laptop
这个答案有帮助吗?
得分 0
添加一条评论
So ASUS TUF A15’s Wi-Fi keeps disappearing, first update your Wi-Fi driver through Device Manager or ASUS Armoury Crate. Disable power saving for the Wi-Fi adapter (Control Panel → Network Adapter → Properties → Power Management). In Device Manager, uncheck “Allow the computer to turn off this device to save power.” Also, ensure your BIOS and Windows are fully updated. Try forgetting and reconnecting to your network or resetting network settings. If the issue persists, reinstall the driver or test with an external USB Wi-Fi adapter to rule out hardware faults.
这个答案有帮助吗?
得分 0
添加一条评论
The problem is because of overheating. The WIFI card is situated right under the HD. The motherboard has 2 slots for a HD (one on left side and one on right), I switched the HD to the other slot (you only need to remove the back panel for this) and no problems since. Also didn't need to mess with BIOS in anyway, the system recognized the HD right away.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Yfan TheNial 将永远感激不已
浏览统计数据:
过去 24 小时: 12
过去 7 天: 73
过去 30 天: 403
总计 3,548
