跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
How to transfer files to new HDD?
My stock HDD is almost full and I want to buy a new one. Problem is I don't want to have a fresh OS X install, I want to save my apps, mail, setup and etc.
How do I clone my HDD if I don't have any USB interface to connect it to the working computer? What are the options to do this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
You have to have something to hook up the new drive. Here is a less expensive option for the external drive especially if you will not need it but for moving your data.http://eshop.macsales.com/item/Newer%20T...
Then download a free application called SuperDuper:
http://www.shirt-pocket.com/downloads/Su...
Hook the drive up with the adapter and clone your data. Then to install the drive, here’s the guide: MacBook Pro 15" Core 2 Duo型号A1211 硬盘更换
这个答案有帮助吗?
得分 4
添加一条评论
Buy a hard drive enclosure. I think I'd first put the new drive in the enclosure and create the clone, then test to make sure the clone boots. After that switch the two drives. When you're done you'll have a bigger drive in your MacBook, plus a little external drive for extra storage.
Of course, backup important files first and don't just rely on the clone—I had a tested, backup clone fail immediately after a clean install! Fortunately, being a crazy person, I had a second clone. :D
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Sergey Rozenblat 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 1,542
