跳转到主内容
加入维修社区 - 创建账户
How to clear check engine light
My car is running smooth but there is an check engine light on meter
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @divyanshsh88361
The only way to clear a check engine light is to fix the problem that is causing the light to turn on.
Get the vehicle's OBDII port scanned using a appropriate scan tool and check what DTC codes (diagnostic troubleshooting codes) are being shown.
The code will tell you what the problem is.
You can cause serious damage to the engine or the transmission if you keep driving with a check engine light on.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
DIVYANSH SHARMA 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 23
总计 737
