跳转到主内容
加入维修社区 - 创建账户
Google Pixel 7a 是 Pixel 7 系列中的经济型机型。Pixel 7a 于 2023 年 5 月发布,在 Pixel 6a 的基础上增加了面容解锁、8 GB 运行内存、大幅升级的摄像头和无线充电功能。
Screen adhesive re-use
Just completed a glass/screen repair on a Pixel 7a, but got a smudge on the front camera lens during the process. Sadly, didn't notice until after reassembly was complete. Can I re-open the front, clean the lens, and re-close without replacing the perimeter adhesive, or do I need to clean up and use new glue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Thanks folks, for the minimal cost of new screen adhesive, it's worth the reassurance that it'll be properly sealed.
由完成的 分享
添加一条评论
2个答案
已选择的解决方案
I'd say it depends on how well the glass comes off. I had an iPhone X that I had just finished working on but banged my head on the table when I realized I'd forgotten to reprogram the True Tone data. So I opened it back up and found that the precut adhesive had stuck on the phone so it was still completely intact and undamaged. That being the case, I decided to reuse it and haven't seen any problem as a result.
So my take on this as it applies to you is, if the display comes off cleanly and doesn't tear or stretch the precut adhesive, you can probably get away with reusing it. If it sticks partly to the screen or tears / stretches when you get the screen off, then it's time to replace it.
One thing you might do when you put the phone back together is to reheat the adhesive once the screen is on, then place it face down with some weight on it. That'll soften the adhesive and the weight will help seal it. Hopefully that'll help compensate for not using a new sheet of adhesive. I usually go over the phone for about 3 minutes with a hair dryer, then I have a motorcycle battery I set on it for a half hour or so.
这个答案有帮助吗?
得分 3
添加一条评论
You could, But I would highly recommend not to
这个答案有帮助吗?
得分 0
2条评论:
Not nay-saying your answer, I'm genuinely curious: voice of experience, or theoretical problem potential?
由完成的 分享
There’s a potential problem
由完成的 分享
添加一条评论
添加你的答案
Frudougy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 33
总计 1,313
