跳转到主内容
加入维修社区 - 创建账户
The Dell Inspiron 15-7537 is a 15.6" touchscreen laptop with an i5 core processor.
No Display, No BIOS got messed up trying to install linux with win 10
Hi Guys,
Let me better describe the situation here. It's an old dell inspiron 15 7537. The hinge of the display was broken long time ago, so i removed it and was happily using it as a dekstop with external monitor, keyboard and a mouse.
As the disaply was removed it use to beep everytime it starts, but everything was fine and i was running windows 10 with secure boot option i think.
One fine day i decided to install linux mint along side with the win 10 using a pen drive and totally messed up i guess with UEFI and legacy mode confusion.
Now all i wanted to access is the BIOS so i can use a pendrive to boot and install either linux or windows from sratch as data in hdd is not a concern for me.
Tried below:
  1. Removed CMOS battery for few min put it back and turn on.
  2. Removed CMOS battery and turn on.
  3. Removed battery and hdd and tried directly with dc power.
  4. Keeping power button pressed for long time.
All the scenario result in same that is when i press a power button all lights trun on including cpu and hdd , cpu fan starts spinning with beep, but there is no signal to my monitor and pressing F2 or F10 simply reboots the device.
Any help is appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@demetronrosta luckily Dell provides a great manual. Here is the one for your Inspiron 15 7000 Series Manual Besides showing you how to replace parts etc, it also tells you how to reflash the BIOS, which may actually be the issue on your laptop. Before that, you may need to try and repair your Bootloader. For that check on here
这个答案有帮助吗?
得分 1
1条评论:
Hi, thanks for the reply.
I checked the link you have shared for repairing the bootloader but the problem is, currently there is no display and i am not able to tell it boot from a pen drive and this model doesn't have cd-dvd support.
完成的
添加一条评论
添加你的答案
Demetron Rosta 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 40
总计 240
