跳转到主内容
加入维修社区 - 创建账户
13英寸铝合金一体成型机身,2.0 或 2.4 GHz Core 2 Duo 处理器。
Optical Drive Not Making Sound at Startup
Hey guys, weird issue. I just replaced the logic board on this MacBook, and now the optical drive makes no noise at startup. Before, you know, there would be a humming and clicking sound and eventually the Startup Chime. Now, just the startup chime. The optical drive works just fine. But, the old logic board will activate the optical drive at startup whereas the new one will not. Everything works just fine, and it doesn't seem to be affecting anything else, I was wondering why it's not doing anything. And, if this is a problem, how could I fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
@danj & @livfe - Turns out is was a firmware issue. My Mac’s firmware was at 1.2, and I needed to update it to 1.4. That’s all it took. The optical drive now sounds great at startup! It’s funny how some of the strangest issues have the most simple fixes!
这个答案有帮助吗?
得分 1
添加一条评论
What you are seeing (really not) is the pecking order of the drives is no longer set to check the optical drive first. Going into the Startup Prefs allows you to alter it.
这个答案有帮助吗?
得分 0
31条评论:
@danj - Where would I change these settings?
由完成的
@jadonlyon System Preferences / Startup Disc / Unlock and highlight the drive ?
由完成的
@livfe - No luck there :(
由完成的
@jadonlyon I wish my 8 'funny' units were that easy to fix..... Love that sound of a mac bootup :)
由完成的
@livfe - Never ever gets old :)
由完成的
显示更多的26条评论
添加一条评论
添加你的答案
Jadon Lyon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 364
