跳转到主内容
加入维修社区 - 创建账户
MSI GL65 9SD 是 MSI(微星)电脑于 2019 年发布的一款入门级游戏笔记本电脑。你可以在此找到维修指南和更多信息。
Why is my screen off
Please a metal screw fell inside the laptop, stacked between the metal that covers the cpu and the motherboard. I didn’t know so I connected my laptop charger to the laptop and the charger light went off. I tried this several times until I opened the laptop and removed the screw. Now the laptop turns on but the screen is off. When I connect to a monitor, it doesn’t show too. Please what could be the fault
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You seem to have loosened the heat sink (that metal part) if the screw got trapped onto the motherboard than it is possible that you damaged the motherboard (really bad). You could also try to check the connection to the GPU and the actual card itself for damage and the fragile ribbon cables around it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael Ashorm 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 235
