跳转到主内容
加入维修社区 - 创建账户
标准款Xbox 360的轻薄升级款,配有250GB硬盘和Wi-Fi功能。维修需要用到复杂且特殊的工具。
How can I fix error code 0020?
Purchased an xbox 360 s from ebay for about 20$, description said it had a RROD but didn't elaborate. When it arrived I checked the error code and it gives me 0020.
Warranty sticker looked like it was half peeled off, so someone for sure tried fixing it before. When it turns on, the power supply light turns green, does that narrow the culprit down at all?
From the research I did there isn't one single reason for the code. What should I do first? Is it worth trying to fix?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@twigg37531 "this secondary error code is caused by the GPU reset communication. If this test is not completed successfully on boot up, you will get this 0020 error code on the Xbox 360 console. This can be caused by TONS of components as there are multiple areas that manage this info, and could be bad." Check for more about that on here as well as on here Most common issue will be the GPU. A reflow might fix this. Going to be a tricky one but for $20 you got nothing to lose. Go ahead, give it a try and let us know how it worked out.
这个答案有帮助吗?
得分 1
1条评论:
Reflowed GPU, still gives the same error code. Anything else I can try or is it just not worth it?
完成的
添加一条评论
添加你的答案
Twigg 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 30
过去 30 天: 125
总计 1,234
