跳转到主内容
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
266 个问题 查看全部
Dsi touchscreen not working at all
Touchscreen on my dsi does not work at all, however problem is in the motherboard, the same screen works perfectly fine on another console.
Tried solder the touchscreen connector, didn’t help. All parts near connector look fine, what can be the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi!
You already tried a lot as I can see! Replacing touchscreen connector didn’t worked.. But the touchscreen does work another DSi.
At this moment it is motherboard related. Did you checked for any shorts on the motherboard? Is everything up to date? Is everything else working fine?
Otherwise, you probably do need to replace the motherboard…
这个答案有帮助吗?
得分 0
2条评论:
I am comparing right now everything with another board, checking for shortages and resistances on different components. Quite difficult to do that without schematics and with no markings on diode/transistor looking components, since I have no idea what are those and how do they work.
完成的
Hmm, can’t find any schematics regarding the DSi motherboard. This indeed takes a lot of time… sorry.
完成的
添加一条评论
添加你的答案
Gleb Anisimov 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 29
