跳转到主内容
加入维修社区 - 创建账户
任天堂于2019年9月20日发布了在Switch系列中更加实惠、且更纯粹的掌上游戏机——Nintendo Switch Lite,它有着一体式的手柄设计以及更小的屏幕。
Capture button isn't working for switch lite
Switch capture button isn't working
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Maria!
What is already tried? Can you press the button or not at all?
Assuming that the Switch is up to date and that you've tried all the resets, the best thing to do is to clean the board on the left and to replace the rubber for the "capture" key. You only need to replace the rubber if you can't click it in properly.
Otherwise, you need to replace the board (left side daughterboard).
This the part you need: https://www.amazon.com/Motherboard-Mater...
Guide: 任天堂 Switch Lite 左操纵杆更换 (till step 27, after replacing the board continue to assemble the Switch again).
Good luck!!
这个答案有帮助吗?
得分 1
2条评论:
All other buttons/joystick full work but capture button is only one not working. It is updated
完成的
Okay, if this is the case, then the board need a replacement. Button has a electronical defect…
完成的
添加一条评论
添加你的答案
Maria 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 171
