跳转到主内容
Repair and disassembly information for Google's Pixel 7 Pro smartphone, released in October 2022. Identified by model number GP4BC and GE2AE.
Where can I buy a replacement LCD display bracket?
I've had to replace my pixel 7 pro screen a few times. The bracket that holds the LCD display flex ribbon snapped, and would like to get a new one before I replace the LCD. Any idea where I can purchase one?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Anyone have any luck finding one of these in stock?
完成的
添加一条评论
4个答案
最有帮助的答案
Hi Michael,
I'm assuming @betatechlabs is pointing in the wrong direction; my impression from reading your question is that you're looking for the metal retainer that keeps the display flex cable from being jarred loose in the case of being dropped; i.e., the one in this picture.
I poked around quite a few obscure corners of the internet, but I'm afraid I didn't have any more luck than you in locating one for sale.
这个答案有帮助吗?
得分 2
1条评论:
Where can I get one of these
完成的
添加一条评论
@michaelnun25749 looks to me like you are referring to these brackets
这个答案有帮助吗?
得分 1
1条评论:
Excellent find, my friend! That listing also gives us the clue that the same bracket appears to be used in both the Pixel 7 and the Pixel 7 Pro.
完成的
添加一条评论
For what it's worth, I have two (technically 3) Pixel 7 Pro's for my wife and I that I perpetually cycle through new screens every few months when one of us drops one or they take a plunge. Since almost every time I open one means a screen replacement (superb build quality), I've had the display cable holder brackets on and off enough times that two have broken so far. I ordered the Pixel 8 display bracket holder iFixit sells with fingers crossed, but it was too small. And I can confidently say a piece of cardboard rolled only lasted a week.
All that to say, I tracked down a supplier, but they're not cheap. They were out of stock everywhere else in the US and on Aliexpress.
这个答案有帮助吗?
得分 1
添加一条评论
What's good Michael? You can buy a replacement LCD display bracket, also known as a front LCD screen bezel frame or LCD frame holder, for your Pixel 7 Pro online from various retailers.
Things to consider when buying a replacement LCD display bracket:
  • Make sure the bracket is compatible with your specific Pixel 7 Pro model. There may be slight variations between models.
  • Consider the condition of the bracket. Some listings may be for used brackets, while others are for new ones.
  • Read the reviews before you buy. This can help you get a sense of the quality of the product and the seller's reputation.
Additional tips:
Replacing the LCD display bracket on a phone can be tricky and requires some technical skill. If you're not comfortable doing it yourself, you may want to take your phone to a professional repair shop.
这个答案有帮助吗?
得分 0
2条评论:
Hey BTL,
Thanks for your reply! The bracket I'm referring to is not a front bezel bracket. Before you connect/remove the LCD ribbon from the mother board, you have to remove a bracket that holds the ribbon in place. It's a small, half an inch piece. Here's a link as an example: https://www.aliexpress.us/item/325680494...
I'd rather buy this piece from another place. It's also out of stock on AliExpress.
完成的
Ah I see. Thanks for the feedback!
完成的
添加一条评论
添加你的答案
Michael Nunez (GoogleMike) 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 50
总计 1,066
