跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for gas, electric, and human powered machines used to cut grass, whether self-propelled or “walk-behind.”
Engine kills when engaged
Engine runs when engaged it kills the engine. There is no binding of the belt.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Loubie, what mower is it and what have you tried so far to fix it?
完成的
Check your safety switched with a multimeter and make sure that they are working right, especially the seat switch. If functions as a killswitch.
完成的
添加一条评论
1个答案
已选择的解决方案
Loubie,
Sounds to me like the engine does not like to run under load.
If you have a local fixit man, go get a good tuneup for the season. If you do not have a local fixit wizard, try to buy and install your own carb rebuilder kit. There are probably several you-tube tutorials on your specific mower or engine or carburetor. However do not worry, as a lot of the small carbs have similar components and operate the same basic way. Additionally, do not worry if you have extra parts in your rebuild kit as some kits are sold generically and contain parts that may fit in a great number of carbs.
Gasoline these days contains ethanol, which gums up carburetors as they sit in the off season. Sometimes chemicals such as "Stabil" help to alleviate this but not always. A lot depends on how long it sit and how much fuel is in the tank and the carb. Change the fuel in your tank also to fresh fuel.
Hope all that helps,
Frank
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Loubie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 411
