跳转到主内容
加入维修社区 - 创建账户
Epson PowerLite Home Cinema 1040 可通过型号 V11H772020 或 H772A 进行识别。这款 1080p 分辨率投影仪于 2015 年 9 月发布,并于 2018 年 2 月停产。
Image display is yellow
Any idea what would cause the displayed image to be completely yellow?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Your projector, when working correctly, probably sends thousands of red, green, and blue dots or rectangles of varying luminosity to the screen. A group of three dots of appropriate luminosity will add up to a grey or white dot. Red and green without blue will add up to yellow. So for some reason apparently your projector is not projecting any blue. If you're lucky it won't be the projector at fault, but instead, a loose or defective cable.
这个答案有帮助吗?
得分 0
添加一条评论
I have the same issue, and I have found that the LCD appears to be going bad. I came to ifixit looking to see if anyone has done an LCD replacement, but unfortunatly there are no guides. This is for my office, so we may just upgrade since it is quite old. However, for the ammount of time that we use it, I would say that this LCD did not last long.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris Lively 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 25
总计 438
