跳转到主内容
加入维修社区 - 创建账户
DJI Mini 2 是一款由 DJI 于 2020 年生产的小型无人机。DJI Mini 2 支持 4K/30fps 视频拍摄,并具备 10 公里 720p/30fps 视频传输能力。
incompatible gimbal data error
powers on connects to drone, camera rotates left,right, up and down can view through camera. gimbal does not respond to wheel on controler. has incompatible gimbal data on display. will not take off. is i a board problem or a cable
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
did you solve this problem?
由完成的
添加一条评论
3个答案
已选择的解决方案
Let's do a little logical thinking here.
If the gimbal does its power on movement then the gimbal and cable to it from its controller in the AC are functional.
If you can view the camera, then the camera system and communication from the AC is functional.
The AC sees the gimbal and is getting data but does not like what it sees, so you are getting an "incompatible gimbal data" message.
Therefore, any commands to it from your Controller are ignored (or maybe the Controller isn't even sending the commands because of the error).
If that message appeared after your "minor" crash, then I would first suspect a dislodged cable in the AC.
But after that, a damaged PCB is a possibility.
这个答案有帮助吗?
得分 2
3条评论:
I'm afraid the reader does not know about an AC being Altitude Controller, nor where to locate this in the drone...
由完成的
AC is a common abbreviation for AirCraft
由完成的
gps board ended up being culprit,bought new still didnt work, took board from another broken drone and all well now.
由完成的
添加一条评论
You will need to replace the gimbal. The best website to buy parts from is: djioemparts.com.
You can buy a new gimbal here for $80 USD https://djioemparts.com/collections/dji-...
Best of luck, BetaTech Labs Repair AU
这个答案有帮助吗?
得分 1
2条评论:
the gimbal responds to startup/power on and does up down left right chk ok and i can view through camera, does not respond to up/down knob on controler so would that be gimbal or motherboard
由完成的
did it beep at startup?
由完成的
添加一条评论
Hi, Have you done any repairs recently? have you crashed recently?
这个答案有帮助吗?
得分 0
4条评论:
very minor fall from about 8' into grass
由完成的
Yeah, it looks like you messed up your gimbal
由完成的
posting new answer...
由完成的
finally was able to find solution, i replaced gps board and all is once again fine!
由完成的
添加一条评论
添加你的答案
colderp 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 29
过去 30 天: 78
总计 2,824
