跳转到主内容
加入维修社区 - 创建账户
USB C Cable Repair - Logitech StreamCam
I have a Logitech StreamCam with a damaged USB C connector. The part number is Dali V04 201927. Where can I find this part?
Update (05/06/24)
and
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @brunogrejo
Here's the ifixit Logitech StreamCam (‎960-001286) USB-C 线缆更换 guide that may help as it has a lot of good information about replacing the cable.
这个答案有帮助吗?
得分 1
8条评论:
Type c connector cannot be found in this guide
由完成的 分享
@brunogrejo
Assuming that you have the same streamcam then the USB-C connector is on the end of the cable (see image), not in the camera.
The camera connects to a USB-C port in a PC via the cable.
If the cable's USB-C connector is damaged either buy a new USB-C cable and cut one end off and then connect the cut end to the camera a shown or purchase a USB-C cable connector (example only) and connect it in lieu of the damaged one
由完成的 分享
My connector in the end of the cable is broken, not possible to use.
Which cable might be compatible, as it has several internal cables?
I can't reuse the type c connector. I don't think the example connector you sent is suitable... there are several internal cables
由完成的 分享
The only reference I have is Dali V04 201927 but I can't find a similar connector.
由完成的 分享
@brunogrejo
Is the connector on the end of the cable that connects to a computer i.e. the one that comes out of the camera, the one that is damaged?
If it is then as I suggested you only have to replace that cable (or connector) as the guide shows how to do this.
The Dali V04 201927 reference is the pcb board that the cable connects to in the camera as stated in this link
This
由完成的 分享
显示更多的3条评论
添加一条评论
添加你的答案
Bruno Grejo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 47
总计 2,269
