跳转到主内容
加入维修社区 - 创建账户
Cen-Tech 七功能数字万用表。型号 90899。
My meter does not work
My meter blinks -1 and if I touch probes together on continuity the blink stops but meter does nothing else.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It would be worth testing the other functions on some references, IE:
will a 100 ome resistor measure at around 100 ome
will a 5v line measure at 5v
If other functions seem about right, you may only need to replace the buzzer inside the meter, so it will beep again.
You can also test if the buzzer gets any voltage if you have another meter to test with.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
wayne shelton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 485
