跳转到主内容
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
Why is my laptop not charging when I plug it in?
My laptop is not charging when I plug it in. I've tried plugging in and out the charging port, and I tested the charger with another laptop. There's no visible damage on the charging port either, it seems perfectly fine. The light isn't lighting up on the charger, even though it does on the other one. What could be wrong?
Update (05/04/24)
It ran out of battery ages ago. Also, the display wire, hinges and clutch cover are broken.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
14条评论:
@hamzas Is it fair to assume it is not starting up when connect to a Magsafe power adapter?
完成的
@oldturkey03 yes, it doesn't start up when connected to a magsafe power connector
完成的
@hamzas So three is absolutely no light (no Amber or no Green light). No sign of life when you plug it in etc.? The MBA appears to be totally "dead"?
完成的
@hamzas let's see if a different Magsafe will work for you :-) keeping our fingers crossed but still having some major doubts. There just seem to be a lot going on with your MBA
完成的
显示更多的9条评论
添加一条评论
1个答案
When you plug in the MagSafe charger does the connector LED lighting up, if it is what color is it Amber or Green?
这个答案有帮助吗?
得分 0
7条评论:
No light at all
完成的
@hamzas - Do you have access to a second charger? As it’s either dead or the MagSafe Port’s dirty or bad being the most likely issue.
完成的
Yes. none of them are working with the mba. I know they work because I have a 2012 unibody mbp i tested them on.
完成的
@hamzas - Then the MagSafe port is either dirty or bad MacBook Air Models A1237 and A1304 DC-In Board Replacement
完成的
Thanks for the help. I'll try it and see if it works
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Hamza Safdari 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 226
