跳转到主内容
MacBook Air Models A1237 and A1304 DC-In Board Replacement
你所需要的
  1. MacBook Air Models A1237 and A1304 DC-In Board Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Unplug your MacBook Air and power it off before you proceed.
    • Remove ten Phillips screws securing the lower case to the MacBook Air:
    • Six 2.8 mm screws
    • Two 3.8 mm screws
    • Two 5.4 mm screws
  2. MacBook Air Models A1237 and A1304 DC-In Board Replacement: 步骤 2 中的图像 1,2 MacBook Air Models A1237 and A1304 DC-In Board Replacement: 步骤 2 中的图像 2,2
    • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Air Models A1237 and A1304 DC-In Board Replacement, Battery: 步骤 3 中的图像 1,1
    • Disconnect the battery connector by pulling it straight out of its socket.
  4. MacBook Air Models A1237 and A1304 DC-In Board Replacement: 步骤 4 中的图像 1,1
    • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
  5. MacBook Air Models A1237 and A1304 DC-In Board Replacement: 步骤 5 中的图像 1,1
    • Lift the battery out of the Air.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. MacBook Air Models A1237 and A1304 DC-In Board Replacement, DC-In Board: 步骤 6 中的图像 1,1
    • Remove the single Phillips screw securing the display data cable ground loop to the upper case.
  7. MacBook Air Models A1237 and A1304 DC-In Board Replacement: 步骤 7 中的图像 1,2 MacBook Air Models A1237 and A1304 DC-In Board Replacement: 步骤 7 中的图像 2,2
    • Lift the display data cable slightly for enough clearance to remove the two Phillips screws securing the DC-In board to the upper case.
    • Lift the DC-In board slightly and pull its connector straight away from the socket on the logic board.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 16,091
