跳转到主内容
加入维修社区 - 创建账户
型号 A2159,EMC 3301。入门级 13" MacBook Pro 的一次更新。提供银色和深空灰色两种颜色。发布于 2019 年 7 月。
Original Battery not recognized
Hi,
I was assembling my macbook pro 13" 2019 and I have this problem: my macbook not recognized the original battery.
Have I damage the battery flex data cable? because, I pulled of this flex cable and I did not open the connector flex of the mainboard.
Photos:
Thank you,
Update (05/03/24)
Continue:
The only way to turn on my macbook pro is: connecting it to the electical network with my power adapter.
Thank you
Update (05/03/24)
Hi Dan,
Photos:
Update (05/06/24)
Hi
I have already had a new flex cable !!! and I have just fixed my macbook pro !!!
Thank you for all answers !!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
So the only way to use it is to plug it into the wall?
完成的
Exactly! That is the only way to use my macbook...
If I install Cocunut Battery... It will show "nan"
完成的
Both connectors seem to be fine and their tabs too, so is it possible that I have damaged the flex cable or the connectors of the mainboard?
I hope I have damaged only that cable...
完成的
添加一条评论
1个答案
已选择的解决方案
Can you post images of both connectors so we can see if they are damaged. If it’s just the cable that’s replaceable MacBook Pro 13" Retina (A1708, A2159, A2338) Battery Daughter Board Cable
Replace the small flex cable that connects the battery daughter board to the logic board.图片
产品
$16.99
这个答案有帮助吗?
得分 1
4条评论:
Hi @danj,
Very close to being a short circuit between connector pins 9 and 10 (from the left) in the 2nd image posted above.
What do you think?
完成的
@jayeff - I would replace the cable for sure, but the real issue is what happed within the connectors.
完成的
@consu - Looking at the connectors they look OK, so maybe all you’ll need is a new cable! I wish you luck!
完成的
Thank you so much for your point of view!!
I will write here when I have the new Flex Cable.
完成的
添加一条评论
添加你的答案
Consu 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 23
总计 472
