跳转到主内容
Nintendo DS 是任天堂发布的第七代掌上游戏机,是继折叠款 Game & Watch 之后,又一款双屏掌上游戏机。
DS not turning on or charging after screen and shell replacement
My bottom screen needed a replacement because there was a black line across it. I also wanted to change the shell while I am at it. Before I worked with my DS, I made sure everything was still working. This included charging, all buttons, game reading. Everything worked fine and so I started and carefully put everything together in the new shell. I tried to power it on but it doesn’t power on anymore. It doesn’t even charge either. I tried reinserting all the ribbon cables multiple times and tried new batteries but that doesn’t work. It has turned to paperweight. How do I figure out what happened? I have a multimeter but I don’t know what part of the DS does what as I’m not experienced with electronics. Any help would be appreciated!
Edit: Did some testing with continuity using my multimeter and it looks like I may have blown a fuse. Idk how since I used padding on the bottom screen to separate it with the motherboard. On the F2, I touched the right side of the F2 and the left side of the battery and my multimeter beeps. Every other combination with F2 and the battery doesn't work. Does that mean the fuse is blown?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hey I’m sorry to hear you are experiencing trouble have you tried to look through our troubleshooting guide?
Nintendo DS Troubleshooting
这个答案有帮助吗?
得分 0
1条评论:
I have. Nothing there really applies to my issue except the under the "Power" section, but that just tells me to try a different AC adaptor and battery, which I have tested before I started and on my other DSs.
完成的
添加一条评论
添加你的答案
realpkmnmaster 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 80
