跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for your Samsung TV.
What could be the problem?
Hello Guys, so i changed backlight bcuz it was blue recently. I bought new ones from aliexpress.After 7days i have been using it a few hours a day maybe. Today i turned it on and it was blue again, i turned it on and off again it was the same blue so i turned it off again. Then i let it rest for like 5 or 10 min and i turned it on to check it again and it was working normally. What could be the issue?
My tv model is UE43TU7102KXXH. It only has one board in it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@patriknemeth first it will depend on how blue, blue is. Next turn your backlight brightness, down let's see if this makes normal lasts longer. I am not to fond of the quality of some of the strips on Aliexpress. There are a lot of "less than good" products. It's always a bit of a hit and miss.
It could be bad backlight strips but there is always the possibility that this is related to the video processor on your main board, or the Gamma IC (less likely).
这个答案有帮助吗?
得分 1
2条评论:
@oldturkey03 it was totally blue, but it was working after that the whole day. Now im curious when i get home that will it happen or not. Could it be that zhe mschines wasnt warmed up or something?
完成的
@patriknemeth anything is possible. My prime suspect are always the backlight strips but let's see if they are now functioning. If so, who knows what was going on with those but just enjoy your TV. .
完成的
添加一条评论
添加你的答案
Patrik Németh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 108
