跳转到主内容
Repair guides and support for your LG TV.
TV screen damage after disassembly?
I was given an LG 50UH5530 for free that had a backlight problem. I replaced the backlight strips ok, but now the picture on the right half of the screen isn't displaying greys correctly. Pure white shows up with slight red tint, black and even colors seem ok, but any mid-grey tones just show up as black. I swapped the ribbon cables to the driver boards and the problem stayed on the same side. Did I ruin the display while I was poking around in there, or is there additional troubleshooting I can do for this?
^ Pure black/white ok, but greyscale all messed up
^ meant to be pure grey screen
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@kylemartin72918 that could still be a backlight issue if you got some "not so high quality" strips. It is also possible that this is related to issues with the driver boards. Check your voltages on the T-con board (use the big inductores to measure) since it is possible that your Gamma IC may be having issues. Of course, double check your work and make sure that all the diffuser sheets etc are properly installed etc.
这个答案有帮助吗?
得分 1
1条评论:
Thanks! I combed over everything and found a small crack in the panel. Not sure if it happened during or before my repair, but I think that's what did it.
完成的
添加一条评论
添加你的答案
Kyle Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 51
