Why does my phone continuously switch off and switch on
I can't use my phone cause it starts switch off and swich on till bettry gtes completely empty
@bhavikrathod could be a bad battery issue. Make sure that it is fully charged and if it does no longer hold a full charge, replace it. Since iFixit does not yet have guides for this use something like this video Now, with a new battery and if it still is doing this, Try to start your phone in safe mode.
If it has stopped to turn on and off in safe mode, you know that the issue is related to a bad third party App. You will have to delete one after the other until you know which one it is.
If none of this works, you may have to try a factory reset. This will not work if your phone continue to turn on and off. For the How-to on that use the information from here
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
Here's what you can do:
这个答案有帮助吗?
@tabathakang you continue to prove that you are missing the point of this site. I can't figure out if this is based on purpose or if it is based on your AI usage. AI doesn't care, I get that. You as the owner of the answers, should care. Those are your responsibilities.
Let me explain to you what is so fundamentally wrong with your answers. Your AI is not explaining anything. Ask yourself if you could fix a single device by following your answers. You know you couldn't. AI is not explaining how to check for updates, how to restart, how to boot in safe mode, what physical damage to inspect or even how to do a factory reset. You are providing a lot of BLAH BLAH BLAH but nothing even remotely helpful. Train your AI and stop using Google and Bing as the source. If you can't train it, don't use it! WEAK! Very Weak.
=== Repair is War on Entropy!!!! ===
how to fix how to fix my on off button not working what should i do
@khemirkhal50165 try the solutions mentioned in the Answer. Let us know what, if anything, worked.
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 95
总计 1,382
5条评论
My phone switch button not working
由 Raju Choudhary 完成的
Battery problam
由 Raj Yadav (Mr_raj77729) 完成的
Power button
由 Rohit Vishwakarma 完成的
Display change
由 Display 完成的
Family display change
由 Display 完成的
