跳转到主内容
It has an identical design as the WONDERBOOM 2. It is IP67 rated for dust and water resistance. Just like previous Wonderbooms, it is capable of floating in water. It still uses a micro USB charging connection!
2 个问题 查看全部
UE Wonderboom 3 Battery dead and not charging
My UE Wonderboom recently died but wont charge anymore, I’ve tried multiple different chargers so I’m pretty certain its the Wonderboom’s battery which is the problem. I’ve seen a few different tricks such as putting it in the freezer for a while or plugging it in for just a few seconds over and over until it starts up. UE only suggests resetting the device but it needs to be on to do so which is absolutely no help. Does anyone have any suggestions? I cant find anyone who will repair a wonderboom speaker near me.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@sopdop "Wonderboom’s battery which is the problem" the best would be to replace the battery. Here is how to do that UE WONDERBOOM 3 Battery Replacement Instructions Once you replace the battery, time to reevaluate the charging situation. You do need to check the USB port since those are definitely the prime suspect.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sopdop 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 49
总计 106
