跳转到主内容
加入维修社区 - 创建账户
Horizontal green lines flash across screen, screen flashes black
Issues started after watching TV for several hours. Has never happened before. Green, horizontal lines flicker frequently on the screen while playing and while pauses. Less frequently, the screen will flicker to black for less than a second and the sound will also pause. Then it will return to normal.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
No image, vertical line and unclear image
完成的
添加一条评论
1个答案
@shauna42507 this "for less than a second and the sound will also pause" would related to the main board because it affects both audio and video. Check the LVDS cables, connectors for tears and frayed contact. Check the heatsink on the GPU as well as the memory IC's. I would try some freeze spray and see if that changes things. We will need to know the exact make and model for your TV and if possible take a look at the boar's as well. Post some good pictures of those with your question. Add them just like you added the video.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shauna 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 53
总计 1,451
