跳转到主内容
Why my speaker is not working good
My phone speaker is not working properly it not sounds good i think some water is in the speaker slot how to fix it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
3条评论
@muhammadar87209 follow the advice given in the original answer or you can try and clean the speaker grill (mesh) first. It may be clogged.
完成的
@ankit5050 is this an answer? Is this a Question? You really need to give us more information if you are expecting some assistance with this device.
完成的
My mobile phone speaker is not working properly
完成的
添加一条评论
2个答案
已选择的解决方案
Because your speaker has faced internal damage, try repairing it by going to a repair shop.
这个答案有帮助吗?
得分 4
添加一条评论
@soumyajitsaha not sure why you would think that the speaker was water damaged. Let's hope it is just the speaker. There is really not much you can do other than to replace it. Since iFixit does not yet have a guide for this, use something like this video You will find out this phone is a bit of a pain in the rear to disassemble. Replacement speakers are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Soumyajit Saha 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 18
过去 30 天: 84
总计 3,399
