跳转到主内容
加入维修社区 - 创建账户
Is there a reset switch?
there is power to the lights control board wont light up and compressor not coming on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Can you verify your exact model number?
由完成的
添加一条评论
1个答案
Theory wise, the control board requires a signal from the freezer temp sensor to run the compressor.
Then the control board supplies power to the compressor.
So, if there is obvious signs of power (lights), then either the control board is not getting a signal to start the compressor, (wiring or thermistor problem), the control board is defective, or the compressor or maybe a start capacitor on the compressor is bad.
I have found a number of control boards with bad capacitors.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael A Dowd 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 30
总计 956
