跳转到主内容
Repair and troubleshooting information for the Dell Inspiron 15 5577, a gaming laptop with a 15.6 inch screen.
10 个问题 查看全部
Motherboard short, how to diagnose?
My laptop quit shut off in the middle of a game, it was plugged in and will not turn back on..
The light on the ac adaptor goes out when I plug it into computer
If the charger port is disconnected from motherboard it dose not go out.
If the charger port is connected and the battery is disconnected it still goes out.
Is it safe to say the motherboard is shorting out and I should just replace it or do i need to do more test? Is there another fix?I don't want to buy the part and still it doesn't work...thanks for the help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@jay3827 you would need the proper schematic and teh component layout for your motherboard. Then you need to measure the components, traces along the part of the circuit for your DC-In jack.
You would have to disassemble your laptop and remove the motherboard. The model for your board should be printed on the topside (facing the keyboard) It is possible that this is a Quanta AM9C DAAM9CMBAD0 but this is just based on what I find.
Use this Inspiron 15 5577 Gaming Laptop Service Manual to work on your laptop.
Update
@jay3827 wonder if that was soot from an exploding part. Post some good pictures of your motherboard with your question. That way we can see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
1条评论:
@oldturkey03 Great article thanks, I took the motherboard out it says model am9b on it..had some black marks like something burnt on fan and next to ram slot that wiped off
完成的
添加一条评论
添加你的答案
Jay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 47
