跳转到主内容
加入维修社区 - 创建账户
其他工具的维修信息。
Tools for smartwatch repair
Hi i am looking for relevant tools to repair smartwatch with respect to hardware and software.
I am using amazfit gts 2 mini
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi @shubh8030
ifixit has a range of pry and opening tools that should be able to open the watch.
Here's a video that may help you to open the watch
这个答案有帮助吗?
得分 3
5条评论:
Thanks for sharing the video it will really help, I am also looking for software tools to fix its software
由完成的
@shubh8030
You may be out of luck as far as software is concerned as the manufacturer's only provides a user manual and EU conformity certificate on their support page for the watch and no software downloads.
You could always try contacting Amazfit on support@amazfit.com and ask them. It never hurts to ask ;-)
由完成的
Yeah I did it but they are asking for money to fix 😄
由完成的
@shubh8030
You never know, replacing the battery might fix the software.
When you have disconnected the battery either do not reconnect the replacement battery for a few hours and then connect and assemble etc and fully charge the battery before turning the watch on or if the Power On button is still connected to the motherboard, with the battery not connected, press and hold the button operated for 30 seconds.
This will drain any residual power from the board and hopefully might correct any software glitches.
Won't hurt to try as the watch is disassembled anyway.
由完成的
That’s good way to give a try thanks a lot will update you soon 👍
由完成的
添加一条评论
  1. An ability to open the device (iOpener)
  2. A razor (not one that you use to shave) (Buy one here)
  3. A spudger (any one works but here is ifixit's)
  4. Tweezers (pointed screwdrivers are important)
  5. Picks (a guitar pick works too)
  6. A screwdriver with a set of screw heads (ifixit's)
These tools are for apple watch repair, your's might be different but hopefully this is all you need
Tools for holding and manipulating small and delicate components. Blunt, pointed, and angled versions.图片
产品
Thin prying tool for opening electronic devices. Opening picks are essential to open any iPad, tablet, or smartphone sealed with adhesive.图片
产品
iFixit Opening Picks (Set of 6)
$4.95
No more adhesive battles! With our iOpener, you can quickly and easily remove glued components in electronic devices whether you're a repair professional or beginner. Apply gentle, even heat to loosen the adhesive holding smartphone, tablet, and laptop case components and batteries.图片
产品
iOpener
$24.95
A large curved razor blade图片
产品
Curved Razor Blade
$9.99
Plastic tools designed to get you in the tightest cracks, without damaging your treasured devices.图片
产品
iFixit Opening Tool
$5.95
With a polymer driver handle and 32 bits, iFixit's Moray Driver Kit offers maximum utility in a compact package. Keep on hand in a kitchen drawer, a car glovebox, or a toolbox.图片
产品
Moray Driver Kit
$19.95
这个答案有帮助吗?
得分 1
1条评论:
Thanks for sharing 😄
由完成的
添加一条评论
添加你的答案
Shubh 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 45
总计 1,199
