跳转到主内容
Xbox 360 是微软于2005年11月22日推出的第二代电视游戏主机。
How do I fix my 360 it says unrecognized disc
everytime i put in a game it says open tray or unrecognized discive cleaned it very well cleaned the lense jus wont work sounds like it wants to but wont
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 13
1条评论
ive dione that with a brand new ganme an it keeps spinning
will not read it
完成的
添加一条评论
3个答案
已选择的解决方案
unfortunately there is no simple solution :(
1. Open your Xbox and CD drive. Clean all optical elements on it.
2. If it did not help find 2 small potentiometers and try to increase voltage on the laser.
3. Replace your cd drive - but you need to reflash a new one with the old cd key.
If you don't understand how it works it will be much better to go to any repair shop - I don't know how much it costs in the US but in London its about 20 quid (just the labour)
Peter
这个答案有帮助吗?
得分 8
4条评论:
+1 Piotr, good answer. kanoa, start off with the easy and inexpensive stuff, clean your laser. You can use a cleaning DVD for that, they are available at most department stores.
完成的
ccccccyuigfddfghjkl;lkjh
完成的
I did this like 2 months ago and my Xbox 360 works like brand new
完成的
But it is not working again now, why?
完成的
添加一条评论
there IS a simple solution. You'll have to open the DVD drive, and replace the laser with an identical one. you can replace the entire "sled" assembly. but the DVD logic board MUST stay with the xbox's motherboard. (unless you have away to flash the board)
这个答案有帮助吗?
得分 1
添加一条评论
We can clean the disc when its recognized disc. All we do is toothpaste and will leave in five mins.Then wash it to see it works.
这个答案有帮助吗?
得分 -1
4条评论:
After u put the toothpaste in the game how do u grt it off. Wipe it run water over it or what.
完成的
I think that toothpaste can destroy the disk
完成的
yes it can do not try that
完成的
Hand sanitizer I use then runic under water and wipe with toilet roll as its softer than kitchen roll
完成的
添加一条评论
添加你的答案
kanoa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 39
总计 47,950
