跳转到主内容
加入维修社区 - 创建账户
Steering and electric problems
The steering is so heavy and the camera is not working what cause this problem car tucson 2013 limited edition
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Greetings Otaku,
Have you checked the fluid level for the power steering fluid? Is the belt slipping or missing from the power steering pump? In addition to this a sudden heavy steering issue is a symptom of a failing or failed lower ball joint.
The camera I would start by checking fuses, wire harness specifically where the camera goes into the back trunk and connections.
Cheers!
Monte
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Otaku Gamesッ 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 16
总计 424
