跳转到主内容
此为等候许久的Mac mini硬件更新。处理器方面支持选配3.6GHz四核i3,3.0GHz六核i5,及3.2GHz六核i7英特尔CPU。
87 个问题 查看全部
A1993 Mac Mini 2018 Not turning on, PSU delivering 12v to 7 pins
Hello there,
I have a Mac Mini 2018 A1993 and it's not turning on at all. When I plug in a power lead and press the power button there are no LEDs and the fan doesn't spin.
I tested the pins on the PSU and 7 of them were 12V. Power to the LEDs and fans were active. The power button does work completely fine too.
Could anyone offer any advice on what I could do to diagnose/repair this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@navneetbedi sounds like your PSU is working. Time to focus on your logic board. "Power to the LEDs and fans were active" let us know where you measured the voltages. Do a visual inspection and check the components carefully. Check for anything that looks odd. You can always post images of what you find with your Question. That way we can see what you see.
Also, remove your RAM and see if that makes a change. I know it should be beeping if it is the RAM but just to be on the safe side. Measure the voltage on the large inductor by the power connector. Let's see if you get 12V on that one.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
2条评论:
Removing the ram didn't make a change, could you point me to where the large inductor is? I couldn't see any odd looking components on the board. Thank you!
完成的
@navneetbedi it will make all the difference if we can see your board, not something from someone else. It's all about you and your computer's issue. If we can see your board, we might discover things :-)
完成的
添加一条评论
添加你的答案
Navneet Bedi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 73
