跳转到主内容
加入维修社区 - 创建账户
Kenmore 品牌 Kenmore 80 Series 洗衣机的维修指南。
No water while spinning
When spinning on rinse cycle the Water used to come on periodically for 3 or 4 seconds then shut off. My machine is not doing this anymore, otherwise it work fine
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @scott10453203
What is the model number of the washer?
完成的
添加一条评论
1个答案
If the water is getting in during other parts of the cycle, would indicate water valve is ok. If equipped , try selecting other cycle modes.. Hot vs Cold , Delicate vs Normal , try to make sure you are getting both Hot and Cold water in. If only one or the other temperature gets in , it is most likely the water valve. The other suspect if both temperatures work, would be the timer, not providing the electronic connections properly. This just general info without knowing your model Make / Model etc.. Good Luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Scott 104 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 219
