跳转到主内容
非苹果电脑键盘维修指南。
248 个问题 查看全部
found rust underneath a plate that holds switches. how to remove rust?
bought a used lioncast lk30 keyboard. it would start to turn on for 3-4 seconds and then suddenly shut off. after disassembling it I found rust on the lever that stabilises the space bar. the lever is underneath the plate that holds switches so it is not removable unless I desoldered 400-500 contacts. Is there any way to remove the rust? any kind of help would be appreciaded :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@arminahmetovic citric acid works wonders when it comes to rust. If it is just surface rust, it should relatively easy resolve by using citric acid on a cotton tip applicator and to clean it. It will help if we can see where and what is rusted. That way we can most likely help you a bit further.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Armin Ahmetović 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 19
