Not working after fall in pool
It was submerged for about 10sec max, took it out, started playing again.
Stopped after a few minutes, never turned on again. Isnt it supposed to be waterproof?
Yes, it has an IP67 rating for ingress protection, meaning it should be waterproof. However, depending on how badly you have use/wore down the device, it only needs one or two cracks/holes for water to seep in through and corrode. My thinking is that it is water damaged.
这个答案有帮助吗?
ip67 означает что он влагостойкий, например можно использовать во время дождя.
ip68 означает что он водонепроницаемый. например можно полностью погружать в воду, но не глубже чем 1 метр и не дольше чем 30 минут
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 31
总计 697
