跳转到主内容
Oppo A37 A37fw 16GB comes with 2GB of RAM. The Oppo A37 runs Android 5.1 and is powered by a 2630 mAh non-removable (as told by Oppo ;-) battery. First released in April,2017.
Why is my phone not switching on?
Customer care say mother board is not ok.
But mother board is not available at customer care service centre
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
3条评论
It is always showing colorOS recovery
完成的
But it lights after it goes off
完成的
Ponsel saya tidak mau menyala,
Di nyalakan hidup sebentar dan ada kedipan di layar,lalu setelah beberapa detik mati kembali,
Kira kira itu apa masalah nya dan apa yang harus di perbaiki?
完成的
添加一条评论
3个答案
最有帮助的答案
@dinesh26778 you need to tell us how customer care checked the motherboard. You also want to let us know what you have tried to fix this. Sure, it could be a bad motherboard but it could also be a few other things.
First you want to check your charger. Make sure it has the proper voltage. Check your charging cable to make sure the connectors are not bend etc. After that, check the charging port. Make sure there is no corrosion, debris etc. that prevents it from working.Clean it of any debris etc, use a few puffs of air to clean it out. Check the DC-in jack of your laptop. If none of this works, get an ammeter and see if your phone draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see 在已经存在的问题里加入图片
If this would be my phone and unless the "Customer care" actually did check the motherboard, my prime suspect would be the sub board (charging board) the flex cable going from the charging board to the main board and the battery. I would replace those before replacing the motherboard. Since iFixit does not yet have any guides for this phone use something like this video to work on yours.
If you do end up looking for a motherboard, then you will have to focus on a used one. New ones made by "Oppo" are not being sold. So ebay or Aliexpress/Alibaba may be your best bets. Careful what you buy so you do not end up with a locked or broken board and lose more money :-)
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 2
1条评论:
i checked this
完成的
添加一条评论
Hp saya tdk bisa menyala di cas juga tidak bisa menyala
这个答案有帮助吗?
得分 0
1条评论:
@sabirurfah We need to know what cellphone (make and model) this is. Next, we will need to know what you have already tried.
I suggest you follow the steps given in my original answer. Then tell us what you found out.
Translation
@sabirurfah Kami perlu tahu ponsel ini (merek dan modelnya). Selanjutnya, kami perlu tahu apa yang sudah Anda coba.
Saya sarankan Anda mengikuti langkah-langkah yang diberikan dalam jawaban awal saya. Lalu beri tahu kami apa yang Anda temukan.
完成的
添加一条评论
My mother board 🛹 s not working well
Update (10/04/25)
My phone is switching off when I start it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dinesh 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 51
总计 1,567
