跳转到主内容
华为子品牌荣耀的修理
317 个问题 查看全部
Honor View 10 Lite battery model
Hi all,
I have to change the battery of a Honor View 10 Lite, but can't find a lot of information about it. The phone settings report JSN-L21 as model, and this is usually associated with Huawei 8X. Does anyone know if I can use a battery for a Huawei 8X or the OEM part number for a Honor View 10 Lite battery?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@dinoo_fixit the battery for your Huawei should be a HB396286ECW. I would not be to concerned about the numbers that pop in your settings report. If nothing else, wait until you open your phone up to replace the battery. Then you can verify the model number from the old one. That way you know for sure and can't go wrong with it.
这个答案有帮助吗?
得分 2
5条评论:
I don't know, also because there are both Honor View 10 and Honor View 10 Lite and there seem to be differences... As the back case is glued, if I disassemble it with a heat gun, then can I reassemble it with new adhesive and keep the old battery? So that I can find a spare once i have a PN
完成的
@dinoo_fixit yes you can do that but why not just keep it open until you have the new battery?
完成的
@oldturkey03 Thanks, because I need it to be working while I get the replacement
完成的
@dinoo_fixit Ah yes, that changes things. You will either take a chance and get the battery ahead of the time or disassemble your back twice. IF it would be my phone, I'd take a chance with the battery number since I am pretty confident about the part number.
完成的
@oldturkey03 Thank you, I'll let you know, as at the moment I do not even have the adhesive
完成的
添加一条评论
添加你的答案
dinoo_fixit 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 44
