I need to replace charger port and daughter board. Are these parts ava
I'm having intermittent charge port connection failure. Is the charger port alone and the charger port/daughter board available as replacement parts anywhere?
@rey63866 typical Motorola numbering system messes everybody up. Check if your phone is a XT2061. Yes, the charging board is available but we need to verify your proper number. IF you already have it apart, post some good pictures of the board with your Question. That way we can see what you see.
If your phone is sitll togethre. go to Settings > About phone > Model > Model Number (SKU)
这个答案有帮助吗?
It is indeed XT2201-3. It was purchased directly from Motorola. It's called Motorola Edge+ (2022).
It has exhibited the usual " only charges when cable is plugged in with certain orientation, turn over plug, doesn't charge or slow charges.
I don't have hot air reflow to mount a new smt usb-c port, which is why I'm willing to purchase the daughter board assembly as long as it's less than ⅔ of the cost of a hot air rework machine. (+-$35) This has been a great phone and I've stuck with Motorola since the first Gen Moto E and G. I'd like to stick with this one for a bit more...
@rey63866 absolutely. I myself prefer to replace the charging board instead of soldering USB-C connectors. It's a lot easier. Looks like the part number for your charging board is SR28C51352 Do an online search and see what it shows you. Always connect with the seller to guarantee compatibility.
I haven't been able to confirm that board will indeed fit. All responses from sellers were "not sure". That said, I just ordered a cheap reflow machine and am trying to figure out which USB-C female connector to get. From a video on YouTube out of central Asia, I looked at a repair on an Edge 30 pro, which seems mostly to be like my phone. It looks like that USB connector has 18 pins. So you know what a PN for.that connector would be? All I see so far are 16 pin and Motorola has been no help.
What is the correct part number for the charging port board (for XT2201-3)? I have the same issue and cannot get a good source to answer this.
Thanks
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 65
